chakravarthy80pcb
Member level 3
pcb part creation checklist
Hi PCB newbie`s,
To become a professional in PCB one should have Good knowledge on the following points :
1.Drawing Schematics in different tools/pkgs (ALtium,PADS, Allegro,..etc)
2.Understanding the errors and procedure of rectifications
3.Board Details understanding
4.Datasheet understanding for footprint creation
5.Footprint Creation
6.Assigning Footprints and linking to the board layout
7.generating Netlist,BOM for different tools
8.General guidelines of layout
9.Placement of Analog ,digital and Mixed signals
10.Pre simulation
11.Adding comstraints for signals
12.Routing techniques
13.Differential and Impedance control
14.stackup upto min 6layers
15.post simulation ( hyperlynx)
16.micro strip and strip line
17.PCI CARD, MOTHER card boards
18.Generation of gerber
19.Verfication Using CAM or Gc prevue or similar to these
20.knowledge on generated files
21.manufacture process
22.Cost of Routing
23.Assembly process
24.Reflow and wave solder
25.Application of the board (used in Land or Air or water)
26.Checklists for Footprint creation,Inputs to pcb designer ,schematic,final pcb ,gerber and documents
once you have good knowledge on the above all ,try to get IPC Designer Certification - CID
All the Best to become a good PCB pro.
chak
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Hi PCB newbie`s,
10.Pre simulation
22.Cost of Routing
23.Assembly process
chak
