hari_preetha
Full Member level 2
I have designed the low noise amplifier(LNA) using pHEMT transistor. I have perfectly designed LNA at 2.3 GHz using coupling capacitors to bypass any AC components, I am sure that my designed LNA is correct.
But I have doubt on the stability setting
When I designed LNA at 2.3 GHZ, When I checked the stability, it shows the following values when linear (S-parameter) transistor is connected.
Stability started from 1.7 GHz and stability ended at 2.4 GHz
When nonlinear transistor is connected, LNA shows the following stability
Stability stated from 1.6 GHz and ended stability at 2.3 GHZ.
I have set the biasing points as Vgs = 565 mV and Vds = 3 V, Ids = 60 mA.
But When I connected LNA PCB mounted components, it is showing Vgs= - 1.02 V, Vds = 4.3 volts, Ids = 300 mA.
I have set the different biasing points and am getting negative Vgs, more Vds and more Ids.
There is no doubt in my LNA design. I have doubt in the stability range setting. For simulation, above mentioned stability values I have set it for the linear and non linear simulation.
For getting proper stability at 2.3 GHz, lower value what value it must be started and it must be ended till upto what frequency to avoid the inconsistent values of the biasing. Can you clarify it.
What could be the other reasons for getting the inconsistent biasing values, while designing LNA.
You are all experienced people, share your experience, I will be benefited and others also benefited.
