syafiq010
Newbie level 2
Need some help regarding how to add another port for second LDR.I got 2 LDR,left and right
LDR left = RA0
LDR right = RA1
Im actually still searching on how to add another reading for my LDR.I just done with left LDR to display the voltage in the LCD.Will provide my program after this..
LDR left = RA0
LDR right = RA1
#include <htc.h>
#include "lcd.h"
#include "adc.h"
#include "system.h"
// Configuration
__CONFIG(HS & // External Crystal at High Speed
WDTDIS & // Disable Watchdog Timer.
PWRTEN & // Enable Power Up Timer.
BORDIS & // Disable Brown Out Reset.
MCLREN & // MCLR function is enabled
LVPDIS); // Disable Low Voltage Programming.
// main function
void main(void)
PORTA = 0; // clear PORT
PORTB = 0;
PORTC = 0;
PORTD = 0;
TRISA = 0b11111111; // set PORTA as INPUT
TRISB = 0b00000011; // set PORTB<7:2> AS OUTPUT , PORTB<1:0> as INPUT
TRISC = 0b00000000; // set PORTC as output
TRISD = 0b00000000; // set PORTD as output
ANSELH = 0; // SET PORTB as DIGITAL I/O for PIC16F887
lcd_initialize(); // Initialise LCD
adc_initialize(); // Initialise ADC
lcd_home();
lcd_putstr("ADC :"); // Put "ADC:" on LDC screen
lcd_2ndline();
lcd_putstr("VOLT: . V"); // Put "VOLT:" on LDC screen
while (1) // Loop forever
unsigned int adc_value = 0;
unsigned int volt_value = 0;
unsigned char i;
adc_on(); // ON ADC
for(i = 0 ; i < 10 ; i++)
adc_value = adc_value + ui_adc_read(); // take the value for 10 times
adc_value = adc_value/10; // Devide the final value by 10 to get the average result
lcd_goto(0x05);
lcd_bcd(4,adc_value); // display on LCD with 4 digit number maximun.
volt_value = (adc_value*50)/102.4; // if adc_value = 1022.
lcd_goto(0x45); // volt_value = (1022*50)/1024 = 499
lcd_bcd(1,volt_value/100); // volt_value = 499/100 = 4 (1st number)
lcd_goto(0x47);
lcd_bcd(1,(volt_value%100)/10); // (volt_value = 499%100 = 99). 99/10 = 9(2nd number)
lcd_bcd(1,volt_value%10); // (volt_value = 499%100 = 99). 99%10 = 9(last number)
* PRIVATE FUNCTION: delay_ms
* PARAMETERS:
* ~ ui_value - The period for the delay in miliseconds.
* RETURN:
* ~ void
* DESCRIPTIONS:
* Delay in miliseconds.
void delay_ms(unsigned int ui_value)
while (ui_value-- > 0) {
__delay_ms(1);
