HOw to 2 interface 2 LDR into 2x16 Lcd using PIC16F887
syafiq010
Newbie level 2
Malaysia
Need some help regarding how to add another port for second LDR.I got 2 LDR,left and right
LDR left = RA0
LDR right = RA1
Im actually still searching on how to add another reading for my LDR.I just done with left LDR to display the voltage in the LCD.Will provide my program after this..
#include <htc.h>
#include "lcd.h"
#include "adc.h"
#include "system.h"
//   Configuration
__CONFIG(HS &			// External Crystal at High Speed
		 WDTDIS &		// Disable Watchdog Timer.
		 PWRTEN &		// Enable Power Up Timer.
		 BORDIS &		// Disable Brown Out Reset.
		 MCLREN &		// MCLR function is enabled
		 LVPDIS);		// Disable Low Voltage Programming.
//	main function
void main(void)
	PORTA = 0;										// clear PORT
	PORTB = 0;
	PORTC = 0;
	PORTD = 0;
	TRISA = 0b11111111;								// set PORTA as INPUT
	TRISB = 0b00000011; 							        // set PORTB<7:2> AS OUTPUT , PORTB<1:0> as INPUT
	TRISC = 0b00000000;								// set PORTC as output
	TRISD = 0b00000000;								// set PORTD as output
	ANSELH = 0; 									// SET PORTB as DIGITAL I/O for PIC16F887
	lcd_initialize();								// Initialise LCD
	adc_initialize();								// Initialise ADC
	lcd_home();
	lcd_putstr("ADC :");							// Put "ADC:" on LDC screen
	lcd_2ndline();
	lcd_putstr("VOLT: .  V");						// Put "VOLT:" on LDC screen
while (1)											// Loop forever
	unsigned int adc_value = 0;
	unsigned int volt_value = 0;
	unsigned char i;
	adc_on();										// ON ADC
	for(i = 0 ; i < 10 ; i++)
		adc_value = adc_value + ui_adc_read();		// take the value for 10 times
	adc_value = adc_value/10;						// Devide the final value by 10 to get the average result
	lcd_goto(0x05);
	lcd_bcd(4,adc_value);							// display on LCD with 4 digit number maximun.
	volt_value = (adc_value*50)/102.4;				// if adc_value = 1022.
	lcd_goto(0x45);									// volt_value = (1022*50)/1024 = 499
	lcd_bcd(1,volt_value/100);						// volt_value  = 499/100 = 4 (1st number)
	lcd_goto(0x47);
	lcd_bcd(1,(volt_value%100)/10); 				// (volt_value = 499%100 = 99). 99/10 = 9(2nd number)
	lcd_bcd(1,volt_value%10);						// (volt_value = 499%100 = 99). 99%10 = 9(last number)
* PRIVATE FUNCTION: delay_ms
* PARAMETERS:
* ~ ui_value	- The period for the delay in miliseconds.
* RETURN:
* ~ void
* DESCRIPTIONS:
* Delay in miliseconds.
void delay_ms(unsigned int ui_value)
	while (ui_value-- > 0) {
		__delay_ms(1);
