How Matching helps during fabrication of Analog IC ?
rameshiloveu
Junior Member level 1
Please help !!!
Thanks and Regards,
Assuming you are toalking about impedance matching. Decreases losses due to reflections and improves signal integrity. maximizes power transfer.
Natural matching of devices lets you take advantage of
differential architectures, compensate one voltage drop
for another, depend on even division-ratios and so on.
The "goodness" of that matching then becomes a concern.
Absolute values are poor in ICs but appropriate techniques can give good accuracy by relying on relative accuracy i.e. Matching.
Keith
the variation of parameters in a multiple device Moses is reduced by matching..... Which also includes the process variations along one axis or two axes... depends on matching
