[SOLVED] how many poles & zeros can be obtained using 3Res 3Cap combinations?
fire_bolt
Junior Member level 3
Are you interested, for any topology, of N energy storage elements, the generalized
analytical max number ?
Regards, Dana.
    fire_bolt
Solution
The video shows that if there are N reactive elements that does not
necessarily imply N poles or zeros. Also discusses poles and zeros
at infinite freq.....
I looked for a paper that given a n node topology is it possible to
predicts.....so far cant find a basis.
Regards, Dana.
For any reactive part X= from either L or C
and for number of Poles ,P and Zeroes, Z
\[ Σ ~Poles_{(max ~ always)}=Σ ~(L+C)=Σ~ Zeros_{(max)}, = Σ~Poles, ~~~~Σ~Z _{(actual)}= Σ~(L+C)−Σ~P_{@f>VHF} \]
Z depends on number of Poles reduced from f at very high freq. such that Xc=0 etc. neglecting parasitics which also affects high f.
    fire_bolt
Thanks you all for your replies. I got it what you guys are trying to explain.
