what's the ADC image sensor output format?
YUV? RGB?
There are quite simple formulas to translate from one color format to another, so it shouldn't be much trouble. Just look into sensor documentation what type of output data it sends and (if needed) do the conversation to 24bit RGB color.
You will find tons of ready to use functions on internet regarding translation between color formats.
What is "8 bit RGB"?
Do you mean 3 bits of red, 3 bits of green, and 2 bits of blue?
Or do you mean that it outputs three 8-bit bytes in sequence, first red, then green, then blue?
hi alzhrani,
The demosaic algorthem is you want.
You can search google by "demosaic" or "color interpolation".
The following is weblink, I search from google. **broken link removed**
