How I can program Xilinx CPLd series XC9500 ???
lollobrigido
Full Member level 2
Full Member level 2
Italy
xilinx cpld programmer
Can someone tell me how I can program these devices? If there is a circuit to build can someone post it?
THX
Lollo
wlwong
xilinx cpld programming
Pls download Xlinix 3.1 or over Software from Xilinx
Bartart
Full Member level 2
Full Member level 2
Europt
how to program cpld
Hi!
When you said program, you mean VHDL/ verilog or phisical programming using prom or via Jtag, any way you can find a lot of schematic designs with CPLDs searching on Google.
example:
Good luck, Bart
Kermit76
Member level 2
Member level 2
cpld program
Download ISE webpack 5.1 and program your CPLD using JTAG.
cdcll
Full Member level 3
Full Member level 3
how to program a xilinx cpld
You also can use an embedded microcontroller such as MCS-51 for XC9500 in-system programming.
maestor
Full Member level 3
Full Member level 3
España
cpld programs
Hi lollobrigido,
I think this is a very generic question.
As Bartart said it depends what you mean.
If you have the code ready to be build into a chip, then you need synthesis and build tools and there is another topic talking about them right now **broken link removed**
If what you want is a mode to download your image to the CPLD then you'll need either a JTAG programmer (which you can buy or DIY, and the IMPACT sw to program it that is free) or any kind of controller to do ISP as cdcll said.
Good luck,
Maestor
Bus Master
Full Member level 3
Full Member level 3
Just behind You ;-)
cpld programer
I have a programmer in P-r-o-t-e-l-9-9 format, tested and working great. Please PM me if you need it.
Thanks in advance.
Yours,
