how generate xilinx coregen without clk
I don't know what a "combination memory core" is, but I believe all the Xilinx memory blocks are synchronous(they need a clock). If you really want non-synchronous memory, and I don't know why you would, you can just instantiate it in your code-I don't think you will be able to use coregen.
how large is your memory, you could used flop instead mems?
You're essentially asking about hardware features of the involved FPGA rather than IP cores. By nature of the block RAM implementation in recent FPGA, the access is synchronous and requires a clock. You'll find details in the device datasheet and specific block RAM user guides.
You can look at your report and see how the tool allocated your ROM, whether it used distributed RAM or Block RAM
Re: Single port block rom in combinational
I believe you know pretty well that combinational block RAM isn't available with recent FPGA, e.g. Spartan, as discussed in your previous thread https://www.edaboard.com/threads/309459/
The answer doesn't change if you shift the question to Verilog coding, beacuse it's still a FPGA hardware problem.
What you are exactly trying to achieve now?
They are given in device data sheet for
https://www.xilinx.com/support/documentation/sw_manuals/xilinx13_2/xst_v6s6.pdf
vROM Modeled With Initial Block Verilog Coding Example
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
reg [15:0] rom [15:0];
initial begin
rom[0] = 16'b0011111100000010;
rom[1] = 16'b0000000100001001;
rom[2] = 16'b0001000000111000;
rom[3] = 16'b0000000000000000;
rom[4] = 16'b1100001010011000;
rom[5] = 16'b0000000000000000;
rom[6] = 16'b0000000110000000;
rom[7] = 16'b0111111111110000;
rom[8] = 16'b0010000010001001;
rom[9] = 16'b0101010101011000;
rom[10] = 16'b1111111010101010;
rom[11] = 16'b0000000000000000;
rom[12] = 16'b1110000000001000;
rom[13] = 16'b0000000110001010;
rom[14] = 16'b0110011100010000;
rom[15] = 16'b0000100010000000;
end
but is created warning
WARNING:Xst:2999 - Signal 'mem', unconnected in block 'rom_blocks_reverse_shifts', is tied to its initial value.
how can i solve this;
How did you connect the ROM? There should be also a statement like below in your code.
do <= ROM[addr];
yes, am also put that statement in my code; but its was not problem; where am put that statement its inside of assign statement or always statement; am try this in both but the warning was came;
initial begin
end
am assigning the value rom[0] = 16'b0011111100000010; inside of initial block means the error came but at the same time am assigning that inside of always block means its did not come;;
but the always block was generated at LUT; am need a block ram; that is a problem;
