eepty
Full Member level 2
For example in a home automation system, a home computer need to control others device through ethernet. They are all connected to a router. However the devices are using DHCP to get the IP address, and as I know the IP address will change dynamically.
So for example if the comupter is switched off for a week. After it is switched one, when it wants to send a TCP package to one device, how does it know where to send?
Thank you.
Thank you.
