On chip PLL
AT-speed-testing means running scan capture at the functional clock freq.
This is also referred to as AC scan, as opposed to normal scan where you run your scan shift/capture at a reduced freq. (scan clk provided by ATE - PLL bypassed)
at-speed test allows you to detect additional fault models such as transitional/delay faults.
while you are capturing during at-speed mode, you need at least 2 pulses at-speed.
And where does your at-speed pulse come from?
PLL
