How does one determine source and destination impedance for high speed simulation
matrixofdynamism
Advanced Member level 2
High speed design requires that one may able to have impedance matched source, path and destination of the signal. The impedance of the path if it is a PCB track can be calculated using the available formulas. As far as I remember, it depends on the track width, distance from ground plane and the dielectric material present between the signal track and ground plane.
What is not clear is how would one determine the output impedance of the signal source and input impedance of the signal destination. As far as I can say, here we are talking about the signal buffer + bonding wire + metal pad/pin on the package of the signal source chip and signal destination chip.
As far as I am aware, we use vendor provided models in simulation for signal integrity purpose. But my question is, how does a person physically use lab equipment to determine the source and destination impedance values themself? I want to know this for general knowledge.
