Jan 5, 2016 #1 S shemo Advanced Member level 4 Joined Apr 26, 2002 Messages 105 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,296 Activity points 709 1) on this diagram when read is high, it will pull the bit line to high. How does register as a read? 2) on write , and let's say /D is high that will pull the bit line low. On both case, where does the bit line go? seems like its either pull up or pull down. I don't see bit line being present to an output.
Jan 5, 2016 #2 G gs65 Member level 1 Joined Sep 9, 2014 Messages 39 Helped 11 Reputation 22 Reaction score 11 Trophy points 8 Location Bangalore,India Activity points 199 Hi, In the diagram that you have attached ,there is no read circuitary. to read the data from sram , we use sense amplifiers (differential amplifier). bit lines will be given as input to sense amp. the output of sense amp will be your dout
