aliyesami
Full Member level 6
am trying to understand how does these LED drivers work with the 0-10v dimmers ., since i don't see any current requirements for the dimmer inputs on the the LED driver nor in the specs of most of 0-10v dimmers I saw.
for example below is the LED driver i want to use , if i connect a analog or digital dimming source what should be its current rating?
https://www.1000bulbs.com/pdf/ac-aca100vd24h41-specs.pdf
P.S: I have posted this topic also on Arduino forum I hope its ok
