How do I automatically get recognization the state enumeration name in simvision?
coshy
Member level 4
How do I get automatically recognization the state enumeration name in simvision?
Hi.
How do I get automatically recognization map the in simvision?
As I knowm SimVision has the ability to map mnemonics to values in the waveform window to make it easier to visualize the states of the FSM.
we need to run the plug-in with ncsim to generate the mnemonics maps. However, those maps can then be used in subsequent post-processing runs of SimVision.
So I want to know how to generate the mnemonics maps automatically not at the post-processing.
Re: How do I get automatically recognization the state enumeration name in simvision
generate them once, by hand. save a simulation setup. load that setup next time you want the same mnemonics. that's how I did it 5 years ago, should still be similar
