wrient
Newbie level 3
1: which command using in TetraMax, then i can work in the LOC Transition Fault ATPG Modes.
2: there are two capture vector , if i use this command:Add_Capture_Masks , which clock it will be working.
TetraMAX transition delay fault ATPG supports three ATPG modes for applying transition
last_shift,
system_clock,
any.
set delay -launch system_clock
set fault -model transition
thanks.
last_shift,
system_clock,
any.
thanks.
