how can see return loss of microstrip antenna in hfss
amir45
Member level 1
microstrip antenna hfss
hell
how can i see return loss of microstrip antenna in hfss
in which menu and which part
antenna return loss
returen loss can be seen in results-creat report-s11.
hfss return loss
hi
you can go to 'HFSS'->'Results'->'CreateReports'->choose display type as 'Retangular Plot' ->Select S(Waveport1,Waveport1) and 'add trace'
best regards
K
return loss in microstrip
Return Loss can be seen as SII in the report meny
return loss in microstrip antenna
create report/s-parameters/add trace/done
return loss in antennas
well can any one tell how to check the ideal feed points on a patch antenna using the HFSS ?? and S11 parameters ? i couldnt understand the s11 parameters as well .. can any body explain..
