How can convert Protel Schematic format to bmp
ha
Junior Member level 1
IRAQ
8) Hey
Any one can help me, how can i convert protel Schematic format to
bmp or jpg format.
Thans.
SnagIt will install a virtual printer driver in your system. Print to that printer and the output will be an image (jpg, bmp,...).
Best,
/pisoiu
Can also use normal postscript printer driver...(or does protel has it's own ps driver?) and print to a file...
Then you can open it either in photoshop/illustrator and save as bitmap/jpeg or use ghostscript to convert the file to bmp...
How about just screen capture?
:) Hey
What about protel pcb ? is it the same way?
Thanks
I guess PCB should have direct option to plot to postscript file...
Otherwise it's the same I assume since protel uses normal windows environment...(that's why I don't like it ;o)
But since you're using Protel you should know better (o;
