shockoshocko
Junior Member level 1
Won't a series capacitor cancel out the function of the ballast and makes it appear as a short circuit ?
Is the ballast you are refreing, a regular choke with winding inside or an electronic ballast?shockoshocko said:Won't a series capacitor cancel out the function of the ballast and makes it appear as a short circuit ?
Before putting exclamation marks behind your statement, you may want to think about the basic circuit properties, particularly the real load. I'm sure, you're able to figure it out.If it is connected in parallel then they would appear like an open circuit?!
Yes, or as I mentioned, you forgot the real load. Actually, the purpose of a PFC is to zero the reactive part of an existing load. Without a real load (the fluorescent lamp) you neither need a ballast nor a PFC capacitor.you are analyzing the wrong scenario
No, it's complex in this case. With a L-R series circuit, you need a smaller C value to zero the reactive part.still not resistive load?
