High speed amplifier with 50ns settling time
engrvip
Full Member level 2
Full Member level 2
high speed amp settling time
can somoene suggest a suitable architecture and techniques i should follow in designing a high speed amplifier with 50ns settling time????
if u have some relevant study material regarding my querry plz give info. regarding it??
thanks
“indirect feedback compensation of cmos op-amps
Hi
it depends your gain too.
maybe simple telescopic cascode
or gain boosted telescopic cascode
regards
It depends on what is you specific for example slew rate, step voltage.... Hard to said possible or not.
It depends on your cuicuit dc gain, gain bandwith. It should can be achieved.
You cant go for telescopic if your voltage is low...
supply voltage is 3.3v
0.35 u technology
have to use it as buffer to drive heavy load.
High i/p and o/p swings needed.
now plz suggest me what architecture should i use......intitially i thought of using class AB ip stage opamp....but then decided to go ahead with Folded cacode architecture.....is it OK to go ahead with FC....as high swings will be a problem in telescopic structure.
i suggest u use folded cascode with CS out put stage it has high swing output, high settling time, use Nmos transistors as differential input
This paper may help you: Indirect Feedback Compensation of CMOS Op-Amps, R. Jacob Baker
Best regards!
I want to add one reminder.
For folded cascode, nmos input pair has a better input gm but poor PM due to the 2nd pole caused by pmos load.
thats right, usualy nmos have higher PM, gain. if ur first stage with nmos, so the second stage is PMOS
best regards
