m_seifi_e
Hello guys
Sorry for wrong topic selection and bad English
I'm working on a project with 3*10 Watt High Power LED's wich act as a frequency & duty variable stroboscope via a Micro Controller . The problem is for accurately stopping a high speed rotary device the duty should be below 2% ( as an experience ) . but with such a low Duty, brightness of LEDs are so low . I know that with higher current pumping to LEDs the problem can be solved . but the question is HOW? and is there a way that current flowing through LEDs be adjusted with selected duty in Code ? would you please help me on over current protection circuity too ?
Thanks a lot
Thanks a lot
