edan
I have a low-end oscilloscope that isn't very sensitive. I'd like to boost the input by at least a gain of 10, ideally 100. I need to see frequencies up to 1Mhz. It's OK, in fact it's better, if the amplifier is an in-line battery powered device.
The first thing that came to mind is to find a 10MHz or 100MHz (unity gain) op-amp, wire it up as a non-inverting amplifier, make a resistor-divider virtual ground with ceramic bypass capacitors directly on the pins, and call it done. I haven't been able to find any fast enough opamps just yet, though I'm sure they're out there. (I live in Europe so going to Digi-Key means paying through the nose for shipping and import.)
Can anyone suggest a common op-amp that's fast enough? Or do you have a better idea?
