Mar 1, 2010 #1 N nnmate Junior Member level 1 Joined Nov 26, 2009 Messages 16 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Ger Activity points 1,415 Hello all, the topic is as mentioned in title, how can i generate a PRBS sequence in Cadence virtuoso (or Spectre?) I m first using Cadence, By Hspice it is rather easy with writing script such as V1 PRBS 0 1 ,,,balabala Is there a similar script log for me to input these signals? thanks! Here i have a paper using PRGS in cadence with smic 0.18um process. Fig 5 shows what i want. https://www.academypublisher.com/proc/iwisa09/papers/iwisa09p425.pdf Thanks
Mar 1, 2010 #2 O oermens Advanced Member level 2 Joined Nov 19, 2005 Messages 525 Helped 107 Reputation 220 Reaction score 44 Trophy points 1,308 Location canada Activity points 3,988 use rand_bit_stream from ahdlLib
Mar 1, 2010 #3 N nnmate Junior Member level 1 Joined Nov 26, 2009 Messages 16 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Ger Activity points 1,415 Thank you so much! I have a problem which is, the random bit rate should be differential. how can i create differential PRBS. Is there a inverter with no delay and convertng the Generators output (low 1V High 1.5V) to (Low 1.5V High 1V)? Thanks. ps i cant use 2x Generator, because they are randomed seperatedly, or? Thanks
Mar 1, 2010 #4 O oermens Advanced Member level 2 Joined Nov 19, 2005 Messages 525 Helped 107 Reputation 220 Reaction score 44 Trophy points 1,308 Location canada Activity points 3,988 there is not_gate in ahdlLib as well.
Mar 31, 2010 #5 M mikeofarrell Newbie level 1 Joined Dec 14, 2009 Messages 1 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Location Canada Activity points 1,284 Just use two sources with the same settings and flip the high and low voltages on them. This should accomplish what you are looking for.
