[PIC] hi, i want help in my project using pic16f877A
rooh
Newbie level 1
hi ,, i musing pic16f877a,, for driving a
dc motor....... right lift farward back...
can any one help me to provide me asm code , hex file . and make file in proteus......plzzz
This tutorial will teach you how to drive a simple dc motor.
It refers to the 876 chip but that is the same as the 877a chip apart from its bigger memory and extra ports, just change the references of 876 to 877a.
http://www.winpicprog.co.uk/pic_tutorial8.htm
Just try proteus, select the chip and a motor, its not that hard to master, plenty of examples on ytube.
Hi Rooh, try this code with MikroC
void main() {
    short duty  = 0; //initial value for duty
  TRISC = 0x00; //PORTC as output
  TRISB = 0x00; //PORTB as output
  portb = 0x00; // init
  PWM1_Init(5000);  //Initialize PWM1
  PWM1_Start();  //start PWM1
  PWM1_Set_Duty(duty); //Set current duty for PWM1
  while (1)        // endless loop
        PORTB = 0x01;  // 1st direction given through RB0
        Delay_ms(10);
        duty = 255;  //max duty
        delay_ms(5000);
        PWM1_STOP();
        portb=0;
        delay_ms(5000); //wait until Motor stop before changing direction..
        PORTB = 0x02;  // 2nd direction given through RB1
        Delay_ms(10);
        delay_ms(5000);
        PWM1_STOP();
Hi, could some one helpe me pleaaase, how to use 2 buttons in portA to invert motor direction
You need one button to change direction.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
void main(){
  unsigned char duty  = 0, toggle = 0, duty = 255;  //max duty; //initial value for duty
  TRISA = 0x01;
  PORTA = 0x00;
  TRISC = 0x00;
  PORTC = 0x00;
  TRISB = 0x00;
  PORTB = 0x00;
  CMCON = 0x07;
  //ADCON1 = ;  //Disable Analog inputs here
  PWM1_Init(5000);
  PWM1_Start();
    if(PORTA.F1){
        Delay_ms(50);
        if(PORTA.F1){
            toggle = ~toggle;
    if(!toggle){
    else if(toggle){
thank you so much jayanth.devarayanadurga
