orsamoo
Hi
I am trying to simulate a spiral coil with HFSS. when the distance between winding is small -(wire dia 0.3mm - when gap is below 0.1mm) I believe the HFSS relate the coil as one chunk of copper.
I see it from the resistance and inductive results.
is there a limit to the gap the hfss can calc? can I fix it using smaller mesh size? the mesh is already small so is there another option I miss in the software?
thanks,
thanks,
