paszczakojad
Newbie level 6
HFSS eats up memory
I'm optimizing a waveguide filter using HFSS 11 and I noticed two odd behaviours:
1. More serious: each iteration eats up some RAM. After 100-130 iteration all 3.2 GB of RAM (I'm using XP 32-bit) is used up and HFSS crashes. After restarting everything works fine (I'm using Quasi-Newton optimizer, so restarting it after an appropriate number of iterations still provides some progress in the optimization process), but that's annoying. When I have an urgent project I have to restart HFSS every 6-8 hours (including waking up in the middle of the night :[ ). I tried different memory limits in Tools->Options->HFSS Options, but that didn't help. Can I fix that somehow? I don't think the optimizer (at least Q-N) needs to have hundred of results in RAM. And even if it needs so - the parameters and cost should be enough, that doesn't need too much memory. I suppose it stores all the meshes in the memory (the 'Save Fields' box in Analysis->Setup1->Sweep1 is unchecked). I really dream about leaving the optimization for a week unattended...
2. Less serious problem: each interation is slower than the previous one - after say 100 iterations HFSS waits for a really long time after each iteration displaying messages like 'updating all derived data centrally'. The cure is to stop simulation, clean up solutions (HFSS->Results) and restart simulation - then it goes smoothly for some time. Restarting without cleanup doesn't help. I tried to check 'Apply variation deletions immediately' in 'Tools->Options->HFSS Options', but that didn't help. I could fix the first problem by using x64 OS and lots of RAM, but after hundreds of iterations the optimization process will be painstakingly slow anyway. Any suggestions?
P.
P.
