Fractional-N
Full Member level 1
- Joined
- Oct 15, 2007
- Messages
- 97
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 2,071
here is my testbench:
and this is the UUT:
when I start the simulation with ISim, I get the ERROR:
please help me resolve the problem.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 LIBRARY ieee; USE ieee.std_logic_1164.ALL; USE ieee.std_logic_unsigned.all; use ieee.numeric_std.all; use IEEE.STD_LOGIC_ARITH.ALL; library std; use std.textio.all; -- entity declaration for your testbench.Dont declare any ports here ENTITY test_tb IS END test_tb; ARCHITECTURE behavior OF test_tb IS -- Component Declaration for the Unit Under Test (UUT) COMPONENT c4KMemory --'c4KMemory' is the name of the module needed to be tested. --just copy and paste the input and output ports of your module as such. PORT ( pRESET : in std_logic; pCLKA : in std_logic; pENABLEA : in std_logic; pADDRA : in std_logic_vector(10 downto 0); pDATAINA : in std_logic_vector(7 downto 0); pCLKB : in std_logic; pENABLEB : in std_logic; pADDRB : in std_logic_vector(8 downto 0); pDATAOUTB : out std_logic_vector(31 downto 0) ); END COMPONENT; --declare inputs and initialize them signal sCLK : std_logic := '0'; signal sRESET : std_logic := '0'; signal sENABLEA : std_logic := '1'; signal sENABLEB : std_logic := '0'; signal sADDRA : std_logic_vector(10 downto 0) := (others => '0'); signal sADDRB : std_logic_vector(8 downto 0) := (others => '0'); signal sDATAINA : std_logic_vector(7 downto 0) := X"00"; --declare outputs and initialize them signal sDATAOUTB : std_logic_vector(31 downto 0) := X"00000000"; -- Clock period definitions constant clk_period : time := 1 ns; BEGIN -- Instantiate the Unit Under Test (UUT) uut: c4KMemory PORT MAP ( pRESET => sRESET, pCLKA => sCLK, pENABLEA => sENABLEA, pADDRA => sADDRA, pDATAINA => sDATAINA, pCLKB => sCLK, pENABLEB => sENABLEB, pADDRB => sADDRB, pDATAOUTB => sDATAOUTB ); -- Clock process definitions( clock with 50% duty cycle is generated here. clk_process : process begin sCLK <= '0'; wait for clk_period/2; --for 0.5 ns signal is '0'. sCLK <= '1'; wait for clk_period/2; --for next 0.5 ns signal is '1'. end process; reset_process : process begin sRESET <= '1'; wait for 7 ns; sRESET <= '0'; wait for 14 ns; sRESET <= '1'; end process; -- Stimulus process stim_proc : process(sRESET,sCLK) file vector_file : text is "vectors"; variable L : line; variable vData : integer; variable good_data : boolean; begin if (sRESET = '1') then sADDRA <= (others => '0'); vData := 0; L := X"00"; elsif (sCLK' event and sCLK = '1') then readline(vector_file,L); read(L,vData,GOOD => good_data); sADDRA <= sADDRA + 1; end if; end process; END;
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; library UNISIM; use UNISIM.VComponents.all; entity c4KMemory is Port ( pRESET : in std_logic; pCLKA : in std_logic; pENABLEA : in std_logic; pADDRA : in std_logic_vector(10 downto 0); pDATAINA : in std_logic_vector(7 downto 0); pCLKB : in std_logic; pENABLEB : in std_logic; pADDRB : in std_logic_vector(8 downto 0); pDATAOUTB : out std_logic_vector(31 downto 0)); end c4KMemory; architecture Behavioral of c4KFIFOMemory is begin RAMB16_S9_S36_instA : RAMB16_S9_S36 -- 16K-bit with 9-bit & 36-bit input/output ports. 8-bit data 1-bit parity, 32-bit data 4-bit parity generic map ( INIT_A => X"000", -- Value of output RAM registers on Port A at startup INIT_B => X"000000000", -- Value of output RAM registers on Port B at startup SRVAL_A => X"000", -- Port A ouput value upon SSR assertion SRVAL_B => X"000000000", -- Port B ouput value upon SSR assertion WRITE_MODE_A => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE WRITE_MODE_B => "WRITE_FIRST", -- WRITE_FIRST, READ_FIRST or NO_CHANGE SIM_COLLISION_CHECK => "ALL", -- "NONE", "WARNING", "GENERATE_X_ONLY", "ALL" -- The following INIT_xx declarations specify the initial contents of the RAM -- Port A Address 0 to 511, Port B Address 0 to 127 INIT_00 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_01 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_02 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_03 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_04 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_05 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_06 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_07 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_08 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_09 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_0F => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 512 to 1023, Port B Address 128 to 255 INIT_10 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_11 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_12 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_13 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_14 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_15 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_16 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_17 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_18 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_19 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_1F => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 1024 to 1535, Port B Address 255 to 383 INIT_20 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_21 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_22 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_23 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_24 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_25 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_26 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_27 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_28 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_29 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_2F => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 1536 to 2047, Port B Address 384 to 511 INIT_30 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_31 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_32 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_33 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_34 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_35 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_36 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_37 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_38 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_39 => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3A => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3B => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3C => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3D => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3E => X"0000000000000000000000000000000000000000000000000000000000000000", INIT_3F => X"0000000000000000000000000000000000000000000000000000000000000000", -- The next set of INITP_xx are for the parity bits -- Port A Address 0 to 511, Port B Address 0 to 127 INITP_00 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_01 => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 512 to 1023, Port B Address 128 to 255 INITP_02 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_03 => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 1024 to 1535, Port B Address 256 to 383 INITP_04 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_05 => X"0000000000000000000000000000000000000000000000000000000000000000", -- Port A Address 1536 to 2047, Port B Address 384 to 511 INITP_06 => X"0000000000000000000000000000000000000000000000000000000000000000", INITP_07 => X"0000000000000000000000000000000000000000000000000000000000000000") port map ( DOA => open, -- Port A 8-bit Data Output DOB => pDATAOUTB, -- Port B 32-bit Data Output DOPA => open, -- Port A 1-bit Parity Output DOPB => open, -- Port B 4-bit Parity Output ADDRA => pADDRA, -- Port A 11-bit Address Input ADDRB => pADDRB, -- Port B 9-bit Address Input CLKA => pCLKA, -- Port A Clock CLKB => pCLKB, -- Port B Clock DIA => pDATAINA, -- Port A 8-bit Data Input DIB => X"00000000", -- Port B 32-bit Data Input DIPA => "0", -- Port A 1-bit parity Input DIPB => X"0", -- Port B 4-bit parity Input ENA => pENABLEA, -- Port A RAM Enable Input ENB => pENABLEB, -- Port B RAM Enable Input SSRA => pRESET, -- Port A Synchronous Set/Reset Input SSRB => pRESET, -- Port B Synchronous Set/Reset Input WEA => '1', -- Port A Write Enable Input WEB => '0' -- Port B Write Enable Input ); end Behavioral;
Time resolution is 1 ps
# onerror resume
# wave add /
# run 1000 ns
Simulator is doing circuit initialization process.
Finished circuit initialization process.
ERROR: In process testbech.vhd:stim_proc
FATAL ERROR:ISim: This application has discovered an exceptional condition from which it cannot recover. Process will terminate. To search for possible resolutions to this issue, refer to the Xilinx answer database by going to http://www.xilinx.com/support/answers/index.htm and search with keywords 'ISim' and 'FATAL ERROR'. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
INFO: Simulator is stopped.
The simulator has terminated in an unexpected manner. Please review the ISim log (isim.log) for details.
