S
slow_rider
I'm trying to design a power supply for a guitar effect. It should work from a 12Vdc power supply as well as a 9V battery. The effect needs supply of 9Vdc, 5Vdc & 4.5Vdc.
The 9V & 4.5V are pretty low or current draw and 5V needed for digital part which draws about 100mA.
I would like to design a simple circuit that could output these voltages and while working with a battery will keep the 9V output for as long as possible. Probably using a switcher. My resources are pretty limited and I am using parts mostly from futurlec.com which carries switchers by national semi. At this point I have a linear regulator for 9V for wall adapter usage and a switcher regulator for 5V output that can take anything down to almost 5V. I need a solution for the 9v feed from battery and a solution for 4.5V supply. Thanks!
