jsmith24
Newbie level 6
Hello all,
Okay, here’s the background and circuit info first:
I'm replacing my aging incandescent tail/brake lights on my old motorcycle with an LED array to try to keep my stator from burning out.
Since the original brake and tail lights use a single bulb with dual filaments, and LEDs have only one conductor, I’ve had to use two different currents to simulate the effect of a second filament. So, when only the tail lights are active, there is a standard current of 20 mA per LED; when the brake light is applied there is a current of 40 mA per LED. The LED array is actually 16 banks of LEDs, so the total tail light current is 320 mA, the brake light current is 640 mA. I have used an LM317T voltage regulator as a current limiter on the tail light “hot lead” and also on the brake light lead, at 320 mA and 640 mA respectively.
Now here’s my question: Since both LM317Ts feed into the same power lead of the LED array, do I *NEED* to place a diode at the output of each LM317T to keep the current from “backflowing”? Or, as I suspect, is the LM317 already biased at the output so that no diode is necessary? The image shows the basic setup (forgive my lack of drawing skill) and necessary current.
In case the image doesn’t show properly, it’s housed at www.falconkits.com/ledbrake/ledbrake.jpg
Thanks!
Jack[/img]
Thanks!
Jack[/img]
