MArnold
Newbie level 3
I am trying to determine if an RF signal is strong enough to be successfully heard by a receiver. Any nudge in getting my calculations correct would be greatly appreciated! I have the following values available from receiver specs and measurements:
P: Signal power at the receiver (watts) - after all antenna gains, path loss, etc.
NF: Receiver Noise Figure (dB) - from receiver spec
B: Bandwidth - from receiver spec
T: Receiver temperature (K) - from measurement in similar experiment
S: Receiver sensitivity (dBm) - from receiver spec
So far, I think I have this much right...
Noise in watts = NF * T * B * Boltzmann
Signal/Noise = P/Noise
So, in essense, I have a unitless Signal/Noise ratio and a Sensitivity in dBm, but I'm not sure how to compare the two to see if that signal is strong enough. Do I have all the data I need to answer the question of if this signal is strong enough?
Thanks!
Thanks!
