[SOLVED] help with a transistor
stephen353
Newbie level 2
Newbie level 2
I cant find a jfet n channel transistor with Vds > 33v at Vgs=0.Some help please?
what the value of Vgs ? can you explain clearly?
in actual,you can find many n channel jfet through the filter tool from the most electronic manufactures,like irfid,freescale,st,etc.
or you can searth use the website https://www.alldatasheet.com type the keyword 'n channel jfet'.
good luck.
There's a few with Vds(max) = 40V here.
You'll have to check the datasheets to see if they can cope with the power dissipation at Vgs = 33V and Vgs = 0V.
