johnkaz77
Junior Member level 1
Hello,i have this circuit which sources or sinks current and i should control Vin- and Vin+ with a pot with its 2 edges connected to a negative and a possitive power supply respectivelly.First of all i would like someone to explain how this circuit works because i don't really understand and second,can i supply the voltages Vin only from one potentiometer as i was told?If the two inputs of the op amp are the same how can it work?Is there something else i have to do and i don't get it?
