help to program FYP-MICROCONTROLLER-GSM-IRRIGATION WATER SUPPLY MONITORING-CONTROL
thibaka
Newbie level 1
any one please help me to compile this program i didnt got the exact gsm.h for this
#include <16F877A.h>
#include <string.h>
#include <stdio.h>
#include <gsm.h>
#use delay (clock=20000000)
#use rs232 (baud = 9600, xmit=PIN_B0,rcv=PIN_B1,stream=GSM)
byte ch = 0;
int count = 0;
byte data[15]; //For SMS storage
byte on[] = {"on"};
byte off[] = {"off"};
byte about[] = {"about"};
byte help[] = {"help"};
byte num[12];
void init_gsm()
fprintf(GSM,"AT\r\n");
delay_ms(1500);
fprintf(GSM,"AT+CMGF=1\r\n");
delay_ms(1500);
void WRITE_TO_EEPROM(int tdata, int location) //write data to eprom at location
write_eeprom(location,tdata);
int READ_FROM_EEPROM(int location) //read eeprom data strored location
int tdata;
tdata = read_eeprom(location);
return(tdata);
void main()
int i = 0;
int j = 0;
int system_on_flag = 0;
int pump_on_flag = 0;
output_high(PIN_D2);
output_high(PIN_D3);
delay_ms(1000);
output_low(PIN_D2);
output_low(PIN_D3);
delay_ms(1000);
delay_ms(1000);
output_low(PIN_D2);
output_low(PIN_D3);
init_gsm();
while(1)
output_toggle(PIN_D2);
delay_ms(1000);
system_on_flag = READ_FROM_EEPROM(0);
if(system_on_flag == 1)
if((pump_on_flag == 0) && (input(PIN_B6))) //PIN_B6 is from soil sensor output
pump_on_flag = 1;
output_high(PIN_D7); //Relay ON
fprintf(GSM,"AT+CMGS=\"%s\"\r\n",num);
delay_ms(1000);
fprintf(GSM,"*** ALERT ***Irrigation Water Pump got Switched ON\r\n");
delay_ms(1000);
fputc(0x1A,GSM);
delay_ms(2000);
if((pump_on_flag == 1) && (!input(PIN_B6))) //PIN_B6 is from soil sensor output
pump_on_flag = 0;
output_low(PIN_D7); //Relay OFF
delay_ms(1000);
fprintf(GSM,"*** ALERT ***Irrigation Water Pump got Switched OFF\r\n");
delay_ms(1000);
fputc(0x1A,GSM);
delay_ms(2000);
count = 0;
fprintf(GSM,"AT+CMGR=1\r\n");
num = get_gsm_sms_number(); //get the phone number from sms
data = get_gsm_sms_text; //get sms message content
fprintf(GSM,"AT+CMGD=1\r\n"); //delete message
delay_ms(2000);
if(strstr(data,on)) //check if the message got on
WRITE_TO_EEPROM(1,0); //data, location (address)
delay_ms(1000);
fprintf(GSM,"Irrigation Water Sensing System got switched ON\r\n");
delay_ms(1000);
fputc(0x1A,GSM);
fgetc(GSM);
delay_ms(2000);
else if(strstr(data,off))
WRITE_TO_EEPROM(0,0); //data, location (address)
output_low(PIN_D3);
output_low(PIN_D7);
delay_ms(1000);
fprintf(GSM,"Irrigation Water Sensing System got switched OFF\r\n");
delay_ms(1000);
fputc(0x1A,GSM);
fgetc(GSM);
delay_ms(2000);
else if(strstr(data,about))
delay_ms(1000);
fprintf(GSM,"B.Tech Final Year(2009-2010) Project.\r\n");
delay_ms(1000);
fputc(0x1A,GSM);
fgetc(GSM);
delay_ms(2000);
else if(strstr(data,help)) //check for help message
delay_ms(1000);
fprintf(GSM,"Send \"on\" to on OR \"off\" to off the Automatic Irrigation Water System.\r\n");
fprintf(GSM,"Send \"about\" to know about me \r\n");
delay_ms(1000);
fputc(0x1A,GSM);
fgetc(GSM);
delay_ms(2000);
