help to calculate propagation constant
red5000
Junior Member level 3
how calculate propagation constant from S parameters, and thanks.
If you mean β then i think it is b=2*pi/λ
    red5000
but if i want calculate β from the field how can i proceed to calculate it ? for example from fdtd
Well I suppose that since in FDTD you know the used frequencies then you know the wavelength range. For example you may know that λ is between 1 and 5 mm hence you know the propagation constant for each frequency (I believe every freq has its own β)...However let me check it out and I'll come back to you ASAP
Added after 13 minutes:
Well according to Pozar there may be another way...
The formula for the resistance of a material is given by this :
η=sqrt(μ/ε)=ωμ/β
where μ is the permeability of the material and ε the permittivity. Of course ω is ω=2πf.
Hence you can easily calculate β for any media like this.
Of course the propagation constant is different for every frequency and every different material.
So in FDTD you'll have a diffrent β for vacuum and different for other materials for any frequency...
Lastly you can calculate η and therefore β using field values like this:
η=Ex/Hy or two filed components perpendicular to each other.
However I strongly suggest finding β for every material using the first formula since you'll have to do it once for every frequency and you won't have any error due to FDTD inaccuracies...
Hope it helps...If you need any help plz ask...
(PS. Thnx for the helped me. Glad to see there is some recognition)
    red5000
but some dispersive materials like ferrites, the wave lenght change when the field pass this materials, then we don't can calculate the beta from the classical formulas, and we must use the numerical solution.
I don't think you can calculate Beta from S parameters.
You can calculate impedances, Return loss etc. using S parameters data.
According to my info Group Delay is calculated in simulation.
For example HFSS.
Refer following document for understanding.
Added after 1 hours 25 minutes:
http://home.comcast.net/~chorneys/Professional/GroupDelayinWaveguides.pdf
Also refer this
    red5000
Well after questioning a professor the answer was:
"You don't calculate the propagation constant from the S parameters. You calculate the ABCD prameters from the S ones and then using those and by employing phase unwrapping you can calculate the propagation constant"
Up to the ABCD part things are easy since you use standard formulas...
Beyond that, it is beyond me. I don't know much on this but if I find out more I'll inform you...
    red5000
Can u send me the circuit diagram of shortwave diathermy...
Shortwave diathermy?
This post is for propagation constant. What do you mean?
thank you for your help somada141
No big deal red5000. Sorry I could be of more help but I haven't delved so far in FDTD yet. If I can help in any way don't hesitate to ask
    red5000
i'm looking for web site who give any pattern program in fdtd and specially for waveguide, if you know one help me please.
i have explained this in another post:
edit: you need to calculate the transfer (ABCD) matrix from matrix. for 2 port networks this is easy using formulae from books. for more ports, you can still find a formula of conversion.
    red5000
