Help required to find fifo depth
bangalore
Hi Sir,
I need to be find fifo depth for this below requirement .
writing frequency -- 32MHZ
reading frequency -- 5Mhz
Data rate is 1 byte.
So what is the fifo depth required for this fifo working properly?
Kindly help me to find this ..
There are (at least) two possible answers:
- write is performed in bursts, then the FIFO must be dimensioned according to burst size
- write is continuous, then a FIFO of any size will overflow
What is the "1 byte" specification meaned to say? A rate presumes that at least two bytes are written with a frequency of xx MHz. A contradiction in terms.
You need to give clear specs. Rate cannot be in terms of bytes. It has be bytes/cycle or something like that. Moreover if the rate is the same on write as well as read side..no FIFO in the world can help you..
If a rate is described as bytes/sec then if the write and read side have identical rates then a properly sized FIFO will never overflow.
I disagree that bytes/cycle is equivalent to a rate.
Well, I made the above statement because his write side freq is higher than his read(1st post) and considering his rate of "1 byte" on both sides of the fifo.
