calculate mobility in bsim3
hello. i'm a new member of this forum and in desperate need for help.
i have just started using a tsmc rf 90nm process and i'm trying to find the parameters of each layer in order to create an hfss model for a transmission line.
The problem is that i can't find the bulk conductivity of the substrate, which i was told that is p-dopped-silicon. Does anyone know a typical value for this conductivity?
Also, i can't find any values for the product μn*Cox for any of the transistors in the manuals and was told to use the BSIM4 Model in order to compute it. Could someone please explain how i actually use this model, because all i have found and downloaded are a few C code files from Berkeley? Do i have to use a simulator and load this model to it? If so, which one do you suggest(freeware if possible)?
Any help will be much appreciated. Thanks in advance!
