amr090
Newbie level 1
error:xst:899
Trying to get this code to work...it runs fine on simvision..but when i transfer the code onto xilinx...i get problems....
Here are the errors!
There are more errors...but they are all this exact format....if someone could help me out by fixing this code itd be great.
link to the project...
module datainout(DataToFPGA, DataFromFPGA, ClrFPGAMem, DataValidToFPGA, DataValidFromFPGA, ClkToFPGA);
input [7:0] DataToFPGA;
output [7:0] DataFromFPGA;
input ClrFPGAMem;
input DataValidToFPGA;
output DataValidFromFPGA;
input ClkToFPGA;
reg [31:0] temp;
reg [7:0] DataFromFPGA;
reg DataValidFromFPGA;
reg [2:0] state;
parameter Sinit = 3'b000;
parameter Sread = 3'b001;
parameter Swrite = 3'b010;
parameter Spause = 3'b100;
integer i;
integer j;
always@ (negedge ClkToFPGA or posedge DataValidToFPGA)
begin
if (ClrFPGAMem)
begin
state = Sinit;
DataValidFromFPGA = 1'b0;
DataFromFPGA = 8'bzzzzzzzz;
end
else
begin
case(state)
Sinit: begin
if(DataValidToFPGA)
begin
i = 1;
state = Sread;
end
else
state = Sinit;
end
Sread: begin
temp[8*(i-1)] = DataToFPGA[0];
temp[8*(i-1)] = DataToFPGA[1];
temp[8*(i-1)] = DataToFPGA[2];
temp[8*(i-1)] = DataToFPGA[3];
temp[8*(i-1)] = DataToFPGA[4];
temp[8*(i-1)] = DataToFPGA[5];
temp[8*(i-1)] = DataToFPGA[6];
temp[8*(i-1)] = DataToFPGA[7];
i=i+1;
if(!DataValidToFPGA)
state = Spause;
end
Spause: begin
i=1;
DataValidFromFPGA = 1'b1;
state = Swrite;
end
Swrite: begin
if(DataValidFromFPGA)
begin
DataFromFPGA[0] = temp[8*(i-1)];
DataFromFPGA[1] = temp[8*(i-1)];
DataFromFPGA[2] = temp[8*(i-1)];
DataFromFPGA[3] = temp[8*(i-1)];
DataFromFPGA[4] = temp[8*(i-1)];
DataFromFPGA[5] = temp[8*(i-1)];
DataFromFPGA[6] = temp[8*(i-1)];
DataFromFPGA[7] = temp[8*(i-1)];
i=i+1;
end
if(i==6) DataValidFromFPGA = 1'b0;
end
endcase
end
end
endmodule
RROR:Xst:899 - datainout.v line 27: The logic for <state> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 28: The logic for <DataValidFromFPGA> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[7]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[6]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[5]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[4]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[3]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[2]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[1]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 29: The logic for <DataFromFPGA[0]> does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 33: The logic for [i] does not match a known FF or Latch template.
ERROR:Xst:899 - datainout.v line 33: The logic for <temp[0]> does not match a known FF or Latch template.
