[help]Problem of cadence ic5141 on fedora4
perylee_sh
Newbie level 6
cadence icfb cant open ciw
I install cadence ic5141 on fedora4 with no errors using a old version tar tool .But following error message show in the terminal when I start "icfb".
Loading "/tools/cadence5141/tools.lnx86/lib/libgdmtdm_sh.so" has failed.
Error (dlopen): "/tools/cadence5141/tools/lib/libvirtuos_sh.so: cannot restore segment prot after reloc: Permission denied
Error (gdmiLoadDMLibrary): Could not load library './libgdmtdm_sh.so' for DM system 'tdm'
Error (gdmImportDMSystem): DM system 'tdm' as specified in file '' is
not available due to errors.
I can not open LibManager in CIW. I am not sure whether ic5141 can run fedora4.
Can someone help me to solve this problem? Thanks.
MSSN
Full Member level 3
cadence ic5141 permission denied on library
I don't know the cause of this error but i run cadence IC5141 on FC4 and i don't get this error
Analogworld
Member level 1
cadence tdm
For FC4, you have to disable the SElinux file in order to get rid of all these errors.
The file is located in:
/etc/sysconfig/selinux
make sure you set the option to disable and then reboot your computer.
Let me know how it works out.
    perylee_sh
perylee_sh
Newbie level 6
selinux dlopen fail
Dear Analogworld
Please tell me how to disable the SElinux file and how to
set the option in detail.
Thanks
llh219
gdmimportdmsystem
In gnome,
you may try to the following steps to disable SeLinux.
Desktop -> System Settings -> Security Level -> SELinux
You can disable the SELinux in this window.
I hope it can help you.
    perylee_sh
perylee_sh
Newbie level 6
gdmiloaddmlibrary
Ic5141 can work very well after I disable the SELinux in
fedora4 just following that Analogworld and llh219 have
told me. Thank you very much!!:D
safwatonline
EGYPT
cadence disable tdm
hello,
can u please specify what u mean by old version tar tool?
thnx
a.safwat
perylee_sh
Newbie level 6
libmanager not opening cadence
safwatonline
you can use tar-1.13.25-11.i386.rpm in fedora4
in order to install ic5141. It can be fount on redhat9.0
install CD.
good luck.
