nidclt
Junior Member level 2
- Joined
- Aug 14, 2012
- Messages
- 24
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Calicut, India
- Activity points
- 1,469
Hi guys, I'm on a project of adding a Fingerprint based ignition system on my car. I've a fingerprint module which will store some finger prints, it will will give a half second pulse(5volt) if the correct fingerprint is detected. I sourced this module from a lock(Adel trinity 788). So the module will give out another half second 5volt pulse after 3 seconds(actually to close the door, which is not needed in my case)
Now let me come to my project. I need to make a 'circuit' that will detect the first pulse from fingerprint module and a relay coil must be activated(to switch ON the ignition of car). This circuit should neglect the second pulse from fingerprint module that comes after 3 seconds. I'm adding a push button to start the engine. Then about the switching off of ignition. The finger print module will send out two pulse as before when I use the finger print module to switch the ignition OFF.The circuit should accept the first signal and the relay should be deactivated to turn the ignition OFF.
This circuit has to be connected to the 'Handbrake' signal of the car. So the finger print works only when the Handbrake is engaged, so I will start and stop engine only when the handbrake is engaged.
I know it will be very simple for experienced guys here, but I'm a bit low with 555 IC and astable multivibrators.
About the voltage part, Finger print module works at 6V and my car voltage is around 12~13.5v
Can anyone please design a circuit that fulfill this needs. Any help is much appreciated.
