Help me understand a pair of sequences
honhungoc
Member level 1
Member level 1
Pls help
I hv a query, pls expain it for me
We hv two sequence A and B
A=[x1, -x2*]
B=[x2, x1*]
Could you please tell me why the inner product of 2 sequences A and B is zero?
A.B= x1x2* - x2*x1 = 0?
Thank u
Re: Pls help
when We have two sequence A and B
A=[x1, -x2*]
B=[x2, x1*]
A.B /= x1x2* - x2*x1 = 0? !!!!!!!!!!!!!
A.B = x1.x2 - x2*x1*
so, if x1 and x2 are real then A.B = 0
Re: Pls help
A and B contain elements which r complex conjgates of one another when dier scaler product is taken da result is zeron dats da condition for orthogonality of 2 complex thingie whether dey r vectors, signals or smthign else!!
Pls help
hinhungoc
I don't think your equation A.B= x1x2* - x2*x1 reflects your problem:
A=[x1, -x2*]
B=[x2, x1*]
Wouldn't it be A.B= x1x2 - x2*x1*??
If not, do you have a mistake with your vectors A or B?
Added after 7 minutes:
honhungoc (sorry about the misspelling)
If your vectors are (rather):
A=[x1,-x2*] and
B=[x2*,x1], then the dot becomes x1x2* - x2*x1 as you indicated in your post.
If so, this does have to be zero, because multiplication of complex numbers is commutative.
(i.e. x1x2* = x2*x1, so x1x2* - x2*x1 = x1x2* - x1x2* = 0)
