zzczx
Junior Member level 3
multicycle path in soc.
I use soc to do apr, but It reported many violated. After read the report, I found it seems the soc encounter doesn't recognize the multicycle path constraint in dc script.
part of dc constrain
soc's report
plz help me to solve this problem. thx
create_clock -name {CLK} -period 14.000000 \
waveform { 0.000000 7.000000 } [get_ports {clk}]
set_input_delay -max 8.700000 -clock {CLK} [get_ports {da}]
set_input_delay -min 7.000000 -clock {CLK} -add_delay \
[get_ports{da}]
set_multicycle_path 2 -setup -end -from [get_clocks {CLK}] \
-through [get_ports {da}]
set_output_delay -max 8.000000 -clock {CLK} [get_ports {db}]
set_output_delay -min 6.000000 -clock {CLK} -add_delay [get_ports {db}]
soc's report
Path #: 1
Startpoint: da
(clocked by CLK R)
Endpoint: db
(clocked by CLK R)
Data required time: 13.400 (minus uncertainty: 0.600 adjusted 1 cycle)
it said 1 cycle ????
Data arrival time: 18.856
Slack: -5.456 (VIOLATED)
Object name Delta r/f (ns) Sum r/f (ns) Slew (ns) Load (pf) Cell Location (um)
da "set_input_delay" 8.700f/8.700r 8.700f/8.700r
da 0.055f/0.055r 8.755f/8.755r 2.900f/2.900r
u15 A->Y (INVX8) 0.758r/0.300f 9.514r/9.055f 2.900f/2.900r 0.236 (164.40, 123.40)
n163 0.004r/0.004f 9.517r/9.059f
u16 B->Y (NOR2X4) 0.267f/0.500r 9.784f/9.559r 0.669f/0.741r 0.203 (177.00, 161.80)
n164 0.005f/0.005r 9.789f/9.564r
u20 A1->Y (AOI22X2) 0.431r/0.115f 10.220r/9.678f 0.703f/0.965r 0.020 (298.50, 181.00)
n166 0.000r/0.000f 10.220r/9.678f
u21 B0->Y (OAI2BB1X2) 0.076f/0.302r 10.296f/9.980r 0.688f/0.700r 0.017 (259.80, 161.80)
db 0.000f/0.000r 10.296f/9.980r
FE_OFC0_yc_mod_1_ A->Y (BUFX8) 0.242f/0.263r 10.538f/10.243r 0.185f/0.291r 0.149 (266.10, 161.80)
FE_OFN0_yc_mod_1_ 0.004f/0.004r 10.542f/10.247r
u22 A->Y (AND2X4) 0.311f/0.348r 10.853f/10.594r 0.154f/0.261r 0.109 (138.30, 251.40)
db 0.003f/0.003r 10.856f/10.597r
db "set_output_delay" 8.000f/8.000r 18.856f/18.597r
