RS6688
Newbie level 2
a question
Who can help me answer this question?I will appreciate you.Thank you.
For the VHDL memory description, the following inputs occur:
For clk1 cycles, N, N+1, N+2, N+3, N+4:
WE1 is 1 on N, N+1
ADD1 is A0 on N, A1 on N+1, A1 on N+2, A0 on N+3
DI1 is D0 on N, D1 on N+1
WE2 is 1 on N+1, N+2
ADD1 is A0 on N+1, A1 on N+2, A1 on N+3, A0 on N+4
DI2 is D2 on N+1, D3 on N+2
a. What is DO1 for N through N+4?
b. What is DO2 for N through N+5?
entity raminfr is
port ( clk1 : in std_ logic;
we1, we2 : in std_logic;
add1, add2 : in std_logic;
di1, di2 : in std_logic_vector(3 downto 0);
do1, do2 : out std_logic_vector(3 downto 0)
end entity;
architecture syn of raminfr is
type ram_type is array (31 downto 0) of std_ logic_ vector (3 downto 0);
signal RAM : ram_type;
signal read_add1 : std_ logic_ vector( 4 downto 0);
signal read_add2 : std_ logic_ vector( 4 downto 0);
begin
process (clk1)
begin
if (clk1’event and clk1 = ’1’) then
if (we = ’1’) then
RAM( conv_ integer( add1)) <= di1;
end if;
read_add1 <= add1;
end if;
end process;
do1 <= RAM( conv_ integer( read_ add1));
process (clk1)
begin
if (we2 = ’1’) then
RAM( conv_ integer( add2)) <= di2;
end if;
read_ add2 <= add2;
end if;
end process;
do2 <= RAM( conv_ integer( read_ add2));
end syn;
WE1 is 1 on N, N+1
entity raminfr is
end entity;
begin
process (clk1)
begin
if (we = ’1’) then
end if;
read_add1 <= add1;
end if;
end process;
process (clk1)
begin
if (we2 = ’1’) then
end if;
read_ add2 <= add2;
end if;
end process;
end syn;
