froten
Member level 3
Hello All,
I'm trying to build a multistage (3 stages) 455KHz IF amplifier. The circuit is a common emitter with primary tuned transformer on the collector. I can not get IF transformers so I have to build them by my self. I have a big problem to design the transformer as follows:
1) What L & C should I use for the primary side for 455KHz?
2) What L should I use for the secandary side?if the next stage input impedance is 3.3K for example.
3) What is the turns ratio should I use? if the next stage input impedance is 3.3K for example.
I realy have seriose problem with selection of L&C and N. Any help is greatly appreciated.
