apart from IO (C++ IO is simpler than C) until you get the classes it is a good intoduction to C and C++ programming
if you are looking for a C/C++ compiler Code::Blocks is easy to use, open source and multi-platform Code::Blocks
it has the advantage over many other C/C++ compilers is when you are working on single file programs you don't need to create a project - just create the source code file, compile and run
