Hello everyone, I want to design a current amplifier for the PLC's analog output, which gives me 0 to 10 Volts with 20mA. But I want 0 to 10 Volts with 500mA using Current amplifier.
Can anyone give me the Transister based circuit or the IC number to solve this problem. I'll be indebt to you.
Re: Help me? How to design Current Amplifier for PLC analog
Can current mirror solve this ploblem?
Or one close-loop gain 25X current amplifer?
Regards,
There are so called "power operational amplifiers" out there ..
For example, take a look at the L272: https://www.fairchildsemi.com/ds/L2/L272.pdf
To ensure 0-10V output voltage swing you should consider +/-12V supply ..
