Help me design a small L-band antenna
Lupin
Full Member level 6
Full Member level 6
Italy
Dear Sirs,
I’ve a question and hope you can answer.
I need to design an antenna with the following features:
- L- Band;
- Narrow band (0,33 %);
- RHCP;
- Delta pattern (two peaks of 12 dB at +/-30 degrees and -30 dB at the centre for ever φ angle);
- Size reduced as much as possible.
I don’t know if using:
- monolayer probe-fed patch antenna with two , four probes with opposite phases;
- planar array of microstrip antennas;
- planar array of helix antennas;
- helical antenna.
Can you give me support about that?
Thanks in advance,
Regards,
Lupin
Re: Antenna design
An axial-mode microstrip helical antenna should be fine to meet your specification.
Re: Antenna design
Can you give me some information about the overall dimensioning about this antenna?
Thanks in advance,
Lupin
