Help me design a fully differential comparator design
mahgoub
Full Member level 1
i want to design a fully differential comrarator that compares two differential
inputs in .13umc tech with delay less than .2ns for low resolution adc
suria3
Full Member level 5
Re: comparator design
Do research on the low voltage comparator design, then you will get the basic idea on the implementation.
mahgoub
Full Member level 1
thanks for the hint but i can not find good material so if have any please send me
qqic
Member level 2
comparator design
search in IEEE
pixel
Advanced Member level 2
For example, fully-differential comparator for 2.5 bit/stage pipelined adc.
You also have more simplified version without capacitors, but with different comparator structure, where threshold is determined by input diferential pair ratio.
mahgoub
Full Member level 1
can you please send me some material about the second comparator
