Help me design a 80dB opamp with 10uF capacitance load
lqy
Member level 3
I need to design a high gain (80dB) OPAMP with a large capacitance load (10uF), It is very difficult to compensate it with a classical two stage OPAMP, could someone please give me some suggestions or practical structures? thanks very much!
willyboy19
Full Member level 3
multi stage gain of op amp
Due to the existence of equivalent series resistance (ESR), there will be a zero created with this 10uF cap. As this ESR resistance can vary by more than 40%, this may cause stability problem if you use a single-stage (such as folded cascode) opamp.
Solution: carefully designed multi-stage opamp.
Chethan
Full Member level 3
Bangalore
Re: A OPAMP design
If the load is just capacitive then a folded cascode opamp would solve ur problem.
Shaber_Mezbah
Newbie level 6
A OPAMP design
try folded cascode or telescopic OTA .. if you are only terget for capacitive load.
pk3316
Member level 2
A OPAMP design
It seems ok, you need two gain stages to maximizee you bandwidth and keep your gain large than 80 dB, and then you need a good class AB output stage to draw large current for the large load cap. for phase margin, use miller compensation.
suthan
Junior Member level 1
Re: A OPAMP design
folded cascode opamp will solve ur problem..try it out !
yeewong_su
A OPAMP design
yeah. I think the AB output with the cascode will be ok
nandi_ranjan
Member level 1
Re: A OPAMP design
Hi
Following Books may help..
The Art and Science of Analog Circuit Design by Jim Williams
Analogue Electronic Circuit Design by Jan Davidse
Electronic Circuit and System Simulation Methods by Lawrence T. Pillage, Ronald A. Rohrer,Chandramouli Viswesvariah
Fundamentals of Analog Circuits by Thomas L. Floyd, Dave Buchla
Linear Integrated Circuits by Jack Winzer
Operational Amplifiers and Linear Integrated Circuits by Robert F. Coughlin
Analysis and Design of Analog Integrated Circuits by Paul R. Gray, Robert G. Meyer
Analog Integrated Circuit Design by David Johns, Ken Martin, Kenneth W. Martin
Analog Integrated Circuits by Edwin W. Greeneich
111 Digital and Linear Ic Projects by Don. Tuite
Analog Integrated Circuits by Miklos Herpy
Analog Integrated Circuits by Grebene
Analog Integrated Circuits by Sidney Soclof
Analog integrated circuit design by Alan B. Grebene
Thanks
Ranjan Nandi
jiaming_lee
Junior Member level 2
Re: A OPAMP design
I agree with you very much. ESR should be considered carefully. Two stage opamp with high current buffer stage can help you. 10p is not a very big load. I ever did one with 10p load in 0.8um process, gain exceeds 100dB
avinash
Full Member level 3
Re: A OPAMP design
with such a high value o/p capacitance you should go for the folded cascode topology.in folded cascode opamp design ,higher the value of load cap will provide much stable opamp.
yaxazaa
Re: A OPAMP design
Don't just think use Miller cap. Instead think by generating a zero through feed-forward.
jinxingsun
Member level 5
A OPAMP design
Self biased folded cascode amp can do!
beckchm
Banned
Re: A OPAMP design
folded configuration self-compensation
Karthikeya
Re: A OPAMP design
you shud try using folded cascode with gain enhancement amplifiers for 80db gain....but i dont know if it can support such high cap load.
also, which technology are you using?in latest technologies it wud be a tough task to achieve that spec...
regards
fasmatikos
Member level 2
Re: A OPAMP design
I agree with Shaber_Mezbah...It work for me , i had a similar project 4 monts ago
krishmaniac
Re: A OPAMP design
anyone can share the design steps for the folded cascode opamp.read through allen's book but got confused.
Added after 37 minutes:
esp when the systemtic offset is specified and input swing is not given.
tjr
Member level 3
Re: A OPAMP design
u refer this opamp design reference manual from Texas
