Help me build a cheap cell phone jammer
tridoshanjay jain
Newbie level 1
Newbie level 1
hi i m tridoshanjay jain .............
i want to make a cell phone jammer in as much as low cost...
i want circuit diag. of it........
pls help...
Re: cell phone jammer
well i don't have the diagram but i can provide you some idea...
well our cell phones operate on 1800-2400 Mhz Career band...so if you just make a circuit which would osciate an produce frequencies between 1800 and 2400 Mhz then the signals from the service provider will not be accepted by the cellphone as your signals will have a stronger power (for a specific area), and this will now allow any other same frequency career to reach near.
Best Regards
you need an old phone and unlock its pll
then strobe up and down the freq output on tx
so jam tx carrier then add 1khz dtmf tone
and ramp up and down as fast as possible
better is an electric motor of a type for jamming radio
has brushes on its armiture rotor cylinder
fixed magnets and coils
the brushes move round the inside of the cylinder and the cylinder has various sizes of ducts on it
the brushes just give sparks
the brushes are made from nickel the whole cylinder is made from brass
and add an antenna to the outer jacket cylinder
And check what else it knocks out, and whether it's actually legal to use in your location....
cell phone jammer
what a very good suggestions............. i wish i had those ideas......... go to google type in schematic diagram of cellphone jammer then you'll have alot of places to look in.....
cell phone jammer
hope this will help
h**p://www.ladyada.net/make/wavebubble/
*=t
check this
Added after 6 minutes:
there are some designs
Hi
Just open the web link
all the best dear
Added after 17 minutes:
Hi again
Here the circuit dear
cell phone jammer
there is many links and file attachement ,search JAMMER in the forum
I don't know which country you are in, but it is illegal to use cell phone jammer in USA.
i have a project on GSM jammer which i would like to sell....
it works perfectly fine for GSM networks and i haven't tested CDMA networks on it...
if anyone from mumbai is interested in buying it can mail me at hallowed_be_thy_name_11(at)yahoo.co.in
Added after 2 minutes:
Added after 50 seconds:
