Help in PIC coding...........
Waran
Newbie level 5
Malaysia
I wanted to know whats wrong with my coding...I wanted to just logic high extra 2 pins which are port B5 and port B6. I put the coding as below. I could compile the coding but when I burn the coding into my PIC18f452, it shows error....Can I know whats wrong with the technique I use?
#include <18f452.h>
#fuses HS, NOWDT, NOPROTECT, NOLVP
#use delay (clock=20000000)
#define m1 pin_C0
#define m2 pin_C1
#define m3 pin_C2
#define m4 pin_C3
#define dir pin_D1
#define brake pin_D0
#define supply pin_B5
#define supply2 pin_B6
#define button1 pin_D2
#define button2 pin_D3
#define button3 pin_D4
#define button4 pin_D5
#define button5 pin_D6
#define button6 pin_B0
#define button7 pin_B1
#define button8 pin_B2
#define buttonstop pin_B4
#define on 0
#define off 1
void main (void)
output_high(supply); // This part which confuse me. Without this part, I could
output_high(supply2); // burn it and run the program.
loop:
if(input(button1) == on && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8)== off && input(buttonstop)== off )
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == on && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop)== off)
output_low(m1);
output_low(m2);
output_low(m3);
output_low(m4);
output_low(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == on && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== on && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == on && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == on && input(button7) == off && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == on && input(button8) == off && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == on && input(buttonstop)== off)
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
else if(input(button1) == on && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == on && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == on && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== on && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == on && input(button6) == off && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == on && input(button7) == off && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == on && input(button8) == off && input(buttonstop) == on )
output_high(brake);
else if(input(button1) == off && input(button2) == off && input(button3) == off && input(button4)== off && input(button5) == off && input(button6) == off && input(button7) == off && input(button8) == on && input(buttonstop) == on )
output_high(brake);
goto loop;
What's ther Error?
Also, you should use the "
" tags when post code in your message.  It will preserve the formatting and make it easier for others to read.
Thanks for replying....
Actually when I burn the HEX file into my pic18f452, the error shows that error in address when it verify Vdd(min) shows in the programmer software...
When I burn the coding without the below line coding, It can run perfectly when put in the circuit....
[ output_high(supply);
output_high(supply2); ]
I define pin B5 and pin B6 as supply and supply2 as stated above.
I am just curious if the line coding I apply in the main code is correct.
The one I highlighted in red in code below is the problem. But when I compile there was no problem. When I burn, It can't burn. Without the highlighted code, my code works perfectly and can burn. The purpose of the highlighted code is to logic high extra 2 pin which are pin B5 and B6. I just wanted to know if the code I highlighted is correct or not. Can I know the way to correct the code if the code was wrong?
#include <18f452.h>
#define m1 pin_C0
#define m2 pin_C1
#define m3 pin_C2
#define m4 pin_C3
#define dir pin_D1
#define on 0
#define off 1
void main (void)
loop:
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
output_low(m1);
output_low(m2);
output_low(m3);
output_low(m4);
output_low(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_high(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_high(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_high(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
delay_ms(1000);
delay_ms(1000);
output_low(m1);
output_low(m2);
output_high(m3);
output_high(m4);
output_low(dir);
output_low(brake);
output_high(brake);
output_high(brake);
output_high(brake);
output_high(brake);
output_high(brake);
output_high(brake);
output_high(brake);
output_high(brake);
goto loop;
Added after 4 minutes:
I used my friends programmer. I do not have it now to burn and send the error report to you. I think the one I highlighted in red is the problem. Can I put the code there to high 2 pins B5 and B6? Or I have to code in different way?
Hello,
I don´t test the code, but have you already tried to use the command set_tris_portB(0b00000000) all zeros ->all pins as output, all ones -> Inputs
Regards
You're not giving me much details to go on, but...
B5 & B6 are the programming pins. There's no reason that using these pins should cause a problem with programming, but if you have a debugger attached while running the program you would get an error.
ll
